I have a Xvid file that I want to convert to SVCD. It has VBR mp3 sound. The file plays fine in WMP, but every time I convert it, the finished product is unsync. It is the kind of unsync where it starts out OK, but slowely throughout the movie, the audio starts to get ahead of the video and by the end it is horrendous. I have converted dozens of other DivX files to SVCD and this is the first one that does this. I have tried using TMPG, CCE, and DVD2SVCD, but none work. I have also tried converting the audio to uncompressed PCM in VirtualDub before I encode it, but that did not work either. Does anybody know why this is happening. I have been trying to figure this out for 2 months now, and it is driving me mad.
One suggestion: Take your PCM (Wav) file and stretch or shrink it to match the video duration. You can do that in Goldwave, it's called Time Warp. Others that I understand can do it are Besweet and Soundforge.
Good Luck."Art is making something out of nothing and selling it." - Frank Zappa -
Have you scanned for bad frames and removed them using this method? Worked for me. :thumbup:
Originally Posted by JIM E
https://www.videohelp.com/forum/viewtopic.php?t=119210 = problem solved
How to author a dvd from several xvid movies without sync problems
By rickywh in forum Authoring (DVD)Replies: 2Last Post: 8th Apr 2010, 14:02 -
Problems with DVDFab when converting DVD TV episodes to Xvid
By ryangarfield in forum DVD RippingReplies: 3Last Post: 11th Oct 2009, 10:38 -
Audio Sync Problems when converting MPG to Divx
By kbehel in forum Video ConversionReplies: 1Last Post: 16th Jan 2009, 21:18 -
Xvid AVI DVD Playback Audio Sync Problems
By lozza_c in forum Newbie / General discussionsReplies: 5Last Post: 8th Jun 2008, 08:38 -
vob/ifo to xvid audio sync problems.
By spiked in forum Video ConversionReplies: 4Last Post: 21st Jun 2007, 17:19
