Greets and Deep Joy
I'm going to be a cheeky monkey and post 2 back to back.
Again been messing around with TMPGENC. Thinking of increasing the size of VCD frame (352 x 288 for PAL) to something like the SVCD spec (480 X 576 for PAL). Also maybe upping the bitrate to say 1800. This is just to get better quality. Would this be defined as an XVCD? Its it the size and bitrate in combination that defines SVCD or is it the way the video/audio stream is compressed.
I know its kind of pedantic - that's the kind of dude I am.
Cake Hole
Hmm... I dont know, but I do not believe it will be compliant and wont work in 99% of all stand alone DVD players that support vcd/svcd.
Good Luck and hope it works
Computers -
The proposed changes are generally classified as XVCD.
A great many standalone players will handle video encoded that way just fine. Check the compatibility list posted on this site if you aren't sure about yours.
Avi to (MPEG1, MPEG2 PS)
By kilee in forum ffmpegX general discussionReplies: 7Last Post: 27th Dec 2010, 18:39 -
remuxing mpeg1 audio to mpeg2
By ChaosOrb in forum Newbie / General discussionsReplies: 3Last Post: 9th Sep 2009, 14:25 -
Question about which is more clear, mpeg1 or mpeg2?
By jimdagys in forum Newbie / General discussionsReplies: 12Last Post: 25th Sep 2008, 01:08 -
how to play high definition mpeg2 on HDTV
By edong in forum Newbie / General discussionsReplies: 4Last Post: 11th Mar 2008, 11:49 -
Mpeg Streamclip_DVD to Mpeg1 or Mpeg2
By edit204 in forum Newbie / General discussionsReplies: 1Last Post: 9th Nov 2007, 10:58
