i kindda new in dvd backup, so please help...
i recentlly purchase a cendyne 4x dvd rcorder. i also have dvdx copy instant copy & dvd2one. however i have a problem when recording my backup movie. when i use dvdx copy to backup my dvd. it come out that 80 % of my movie is in perfect condition & quality, but the other 25% or the last episode of the movie is frezing or pausing too much. i did to all the movie that i have but it come out the same thing. then i get instant copy. it did the same thing as 80 % perfect and 25% pausing or frezing. I want to ask it is because i use windown xp or i need to configue something in the system in order to make a 100 percent backup dvd.
my computer is P4, 1.5 Gb processer, and win xp.
i use khypermedia and Memorex dvd-r to backup my movie.
please help i be very appriciated...
i also have another problem w/ dvd2one. i hear that using dvd2one can put dvd9 to dvd5 to did try it. it work great with i use nero to burn it. however it only play in the computer. when i put my backup dvd to dvd player it not response. i want to ask it there any way that i can burn it and play on the stand alone dvd player. i use the method the people in vcdhelp provide to burn, which is after i rip in the hard drive using dvd2one. then use nero dvd (udf) 1.02 to burn it to the dvd-r. but it doesn't work in stand alone dvd player. please help... i use over 20 dvd-r and waste them all trying to burn it.
Since you already have Nero use ImgTool 1.00.4 to burn your DVD it works everytime.
Get it here
http://www.doom9.org/index.html?/software2.htm -
does your DVD player support DVD-R?
do you have an AUDIO_TS and VIDEO_TS folder on the disc?
if most of the movie plays and you are getting glitching/pausing towards the end it is either the player or the media....my guess is it is the media. many people have trouble with cheap media...and I am pretty sure khypermedia is aftermarket media -
i had the same problem with memorex dvd-r on my toshibia machine, but not on my sony. I use ritech and accu and don't have that problem on either one anymore. Memorex disks will do that on several dvd players.
actually it sounds more like a media problem to be honest, when I had a bad batch of disks this is what happened to me & simply choosing better disks will sort out this problem!!, princo media does not work to well on a pioneer ao5 coz thats what your drive is.. what works are ritek, datasafe 2X media (not prodisc) vivistar, verbatim, TDK & a few others but stay away from princo based media as it will screw up.
thank guy for reply
i try to find some different type of dvd-r media and try it out to see what is going on... by the way, does any know a place that sell ritek, vivistar, verbatim, TDK accu or other that you think is going to work on my machine. thank... guy...
anyway dssgorila, i have use that method but it only work in computer not on my dvd player. moreover, i check the file it only have the VIDEO_TS file. my dvd player support dvd-r which i have backup one disk with an hour movie long and it seem to work fine. but when i burn movie over an hour (which most of my dvd have), it doing just like before... -
www.supermediastore.com they have ritek. I got the bundle 100 dvd-r and 100 cases for $130.00 but I just looked and the price went up to $180.00. I should of stocked up if I knew prices were going up.
How do I rip a DVD, trim part of it (beginning & end), and copy onto DVDs?
By aple in forum Newbie / General discussionsReplies: 5Last Post: 11th Jul 2011, 19:04 -
How to copy DVD 9 to 5 with menu & extras using DVD2ONE.
By BarryHL in forum User guidesReplies: 145Last Post: 24th Mar 2011, 09:36 -
Hellllp!! Need to copy a DVD to >>VHS w/everthing hooked to a HT amp
By MISS CHIEVOUS in forum Newbie / General discussionsReplies: 25Last Post: 31st Oct 2009, 12:58 -
Can I copy & play from an incompatible DVD format to a compatible one?
By akersaz in forum MediaReplies: 8Last Post: 14th Mar 2008, 20:07
