Greets and Deep Joy
Been missing around a bit with the settings in TMPGENC. Anyone know what the difference is between the motion search (fast) option and highest quality (slow) one.
Its just that I can't actually see any difference in quality the motion search looks great and needless to say the big plus is that it takes almost half the time to do the encoding.
Alan
PS Isn't TMPGENC a great piece of software, when is it going to stop being a beta ie when are they going to start charging for it?
Are you encoding an MPEG file or AVI file? From what I found it doesn't matter what setting you use if you're encoding an MPEG file (obviously you will choose the "fastest" setting).
I dont use the Fastest setting. It takes me 2 hours to encode an entire DVD movie into VCD at the Highest Quality (Very Slow) setting with Floating Point and Soften Block enabled. Not to brag or anything lol
Computers -
I think Motion Search is basically takes a big guess at what the fps and sync are instead of actually FULLY analizing it. So basically, its not as accurate as if u encoded at NormaL speed or higher, though I dont use it that much, Sorry I couldn't b of more help.
Computers -
I don't work with AVI much, I find MPEG a LOT faster and more efficient to encode
Diamond Search for motion estimation
By bijo911 in forum ProgrammingReplies: 2Last Post: 10th May 2011, 19:26 -
google search pages keeps erasing my search criteria -- [RESOLVED]
By vhelp in forum ComputerReplies: 0Last Post: 5th Mar 2011, 17:27 -
best motion search option to increase encoding speed while keeping quality?
By visualhippocracy in forum Video ConversionReplies: 4Last Post: 13th Jan 2011, 11:40 -
Search Excel Spredsheet Data in Vista Search
By mn072065 in forum ComputerReplies: 11Last Post: 29th May 2009, 01:26 -
Divx Bitrate Adjustment - Low Motion or High Motion? TmpgEnc Xpress 4
By Sliztzan in forum Video ConversionReplies: 5Last Post: 31st Aug 2008, 21:11
