Does anyone have this card or know if its good.
I used to have that crappy ATI TV Wonder and I returned it
Is the TV2000 XP Deluxe worth it?
I want to capture tv and take from video tapes and vhs,
And get them on my computer to burn to vcd on my 65inch widescreen at great quality,
Thanks![]()
Get the ADVC-100 .. I've tried various TV Tuner/capture cards and it's always missing that little something
. The ADVC converts analog video signals to DV AVI and got no TV tuner built in. Since you are going to capture VHS, so presumably you are going to connect a VCR to it anyway, use that as your TV tuner
THANKS for the reply but
I want to capture from the tv we got rid of most our vhs playes in our house when I do convert I will brind the one from my siters room to mine.
So you think the TV2000 XP Deluxe is worth it?
I have no clue what the capture resolution is? -
Sorry.. have got no clue
Maybe someone else can help you. Gave up on those cards since I got the ADVC-100 :P
This is a very good quality card for the price, however there are much better (more expensive) ones out there. I mostly use the card for TV viewing and not capturing. I have experimented with capturing a little and have found it to produce good quality results. I usually capture straight to DVD mpeg2 to avoid reencoding. I you purchase this card I would avoid using the software provided to capture as it can sometimes be a bit buggy and is also annoying to look at (flashing lights and funky colors.) It does have an excellent scheduler function however and the card comes with a cool looking remote. All cards have there pros and cons but I personally like this card and think it would be suitable for what you plan on doing.
nf -
Oh ty verry much!
Do you know any cards that I can do what I want to with?
TV2000 XP Expert No Sound
By cbr549 in forum Capturing and VCRReplies: 5Last Post: 5th Dec 2010, 13:29 -
Trying to use VirtualVcr with Leadtek Tv2000 expert.
By GLE3 in forum Capturing and VCRReplies: 0Last Post: 20th May 2009, 10:46 -
Help: No sound at all with a Winfast TV2000 XP Deluxe
By Deathwish238 in forum Newbie / General discussionsReplies: 3Last Post: 18th Aug 2007, 13:01 -
Problem with WINFAST TV2000 XP Expert tv capture card.
By trueman in forum Capturing and VCRReplies: 1Last Post: 5th Aug 2007, 12:00 -
Leadtek Winfast TV2000 xp deluxe help
By Nuwanda in forum Capturing and VCRReplies: 0Last Post: 6th Jun 2007, 14:22
