    Jan 2003
    Lighthouse Cove, Ontario
    Hey all,
    I capture using virtualdub to avi... and it looks phenomenal. However i want it converted to SVCD, but when i encode it using TMPG (i know how to use TMPG fairly well, and have encoded many movies already), the high motion areas get all pixelated (such as a mosh pit scene when everyone is jumping up and down) is there any way to prevent this? and make it stay clear (i know it is not a lossless program) like the original avi, im just wondering about any settings that might reduce that effect on high motion scenes.
    Syndrome
  2. Member Conquest10's Avatar
    Chicago, IL
    you might want to use multipass vbr with a higher max. if the bitrate is too low, you will get the pixelation.
  3. Yea I know, I had the same problem yesterday, I'll try the "multipass vbr with a higher max".
