  1. Hi,
    Im considering building a PC just for doing video /editing work, what specs does anyone recommend, i.e should i get a AMD 1.4ghz or a Pentium 4 1.xghz etc
    Look forward to your comments
    Zed
  2. From what I read I am looking at the following type of system:
    Dual pentium 4 or athlon processors (MB + chips ~$600)
    Windows XP pro (multiprocessing)
    512MB RAM min
    DVD & CD-RW drives (plextor would be nice)
    2 60 GB drives (one OS, 1 for movie making)
    Firewire (SCSI would be nice too)
    Would dual processors and the SMP of XP be good - we'd see
    Sep 2000
    Northern Virginia
    one recommendation put out by the videoguys as of feb 2001
  4. For faster, more heated responses, you should have
    typed "AMD vs INTEL" or "Athlon Vs P4" in the
    subject field.
  5. No flame, but this kind of a silly tread because for home video editing, there's no such thing as too much Buy the biggest/fastest system you can afford.
    Personally I like AMD over Intel (see other treads about that). For just video editing I think intel might have a slight edge Mhz/Mhz. But AMD is so much cheaper you can buy a much faster CPU and supports current PC133 ram (which costs nothing).
    I have a Tbird 1.2Ghz 266FSB w/ 512MB PC133 ram (have another 512MB I plan to install when I upgrade to win2k), 60GB 7200 ATA100 HD, and a 40GB 7200 ATA100 HD. I can encode at 1~1.25x the source runtime with CCE.
    As for video capture, it seems like a lot of people can caputre at 720x480 30fps w/ 500Mhz machines.
    Now for linear/non-linear editing - the system is 'good enough.' Meaning I can setup, scroll, preview, spilt screen, etc. but there are pauses and waits to load. And I can't run anything in the back ground. This is with MovieXone and ULead.
