Hi,
I am tring to encode AVi's in CCE 2.5 and i have a avisynth script but it make the picture wide but not high. Is their a program that will tell me what to resize the avi at, any prog that will auto create avi scripts?
I have tried fit cd but its no good.
Any hep would be great
Dob
What was your problem with FitCD? Because that is what I use and was going to recommend.
Thanks for your promt reply Faceman101,
FitCD gives a avisynth script but the movie i am encoding is squashed and people look taller then they should be.
Any ideas?
Dob -
Did you check the anamorphic button by your source or destination?
What is the resolution of your original AVI and is it anamorphic to begin with?
Is there a way to see actions done by scripts?
By Marc01FR in forum ffmpegX general discussionReplies: 1Last Post: 21st Jan 2011, 14:27 -
aviSynth + CCE Basic (2.7) fails on certain scripts
By binister in forum Video ConversionReplies: 6Last Post: 11th May 2008, 00:23 -
What are your favorite nautilus scripts?
By freebird73717 in forum LinuxReplies: 2Last Post: 16th Feb 2008, 17:28 -
Are these scripts right?
By php111 in forum Newbie / General discussionsReplies: 7Last Post: 21st Jan 2008, 17:10 -
Scripts for Conversion
By jwfc in forum Newbie / General discussionsReplies: 2Last Post: 6th Nov 2007, 06:50
