  1. Okay I pay no attention to all the feedback about this cd/vcd/mp3 player but I bought one.. GRRRR! for what it is its good but for the life of me I want to know how the hell can i burn a vcd that will play properly on it without it jerking like an epileptic... far from offering it some medication can some body please shed some light about how to do this... by the way it plays bought ones quite nicely just wont play the rips properly..
    Cheers Kev!
  2. still nobody out there willing to help me with little player!! please can some one help with the above message.
    Thanx
  3. If you do a search on this forum you'll find several suggestions already posted. The simplest fix I found (just like you I bought one in spite of the reviews) that gives satisfactory results is to encode a standard VCD at a bit rate of 1123 instead of 1150. Just by lowering the bitrate that small amount (which still meets the standard) my VCD's will playback without making me sea sick.
  4. Thanx for the help... been on holiday so this is the first time i've seen the reply thanx again... I've seen the other people having the same bother but I'll try the lower bit rate all the same..
    Cheers
    Kev!
