Can somebody answer these questions for me?
1) Quality wise, is 2 pass vbr with TMPGenc equal to 2 pass vbr with cce? or are more passes needed?
2) In avi2svcd, is setting multipass pass vbr number of passes to 1 the same as selecting one pass vbr?
3) I read that selecting 3 passes in cce is actually doing 4 passes (because of the vaf?) and that in terms of encoding, anything beyond 4 passes is wasted. Does this mean I should set the number of passes to 3 (which will make 4 passes) or actually set it to 4?
4) Would there be a very noticible quality degradation if I lower the number of passes to 2 (or even 1)? I'll be mainly encoding anime movies.
5) Is there a way to encode movies with ac3 to play on stand alone players using only avi2svcd?
Sorry if any of these questions are too stupid/noobish. Any help would be appreciated.
Originally Posted by namreh
3pass in CCE (ie 4 total) takes about the same time as CBR encode in TMPGenc.
Originally Posted by namreh -
Originally Posted by Vejita-sama
I'm not sure if that's what you meant but I didn't want anyone to get a wrong idea."Art is making something out of nothing and selling it." - Frank Zappa -
No you are of course correct. I kind of forgot about that aspect of VBR encoding. When I use to make xSVCDs I had a general rule of thumb that worked out well for me. Less than 60min/80min CDR, 3pass VBR (300,1800,2520) with audio at 128kbit/s.
But I've since stepped up to DVD-RW and really don't remember all the 'tips & tricks' setting wised I used for x(S)VCDs. And it really is a personal choice. Plus it varies from video to video (that is high motion vs. low motion video).
Anime is really hit and miss with this. Some series are nothing but a collection of stills, others are non-stop high speed motion. -
One day we'll all have DVD-R and then we can all forget about VCD/SVCD!
I have been attempting multipass encoding with CCE and when ever I select two or three passes under the multipass VBR tab, CCE will crash. Here is the last script that I tried.
LoadPlugin("C:\Program Files\DVD2SVCD\MPEG2Dec\MPEG2DEC2.dll")
avisource("elor12nb.avi")
BicubicResize(352,480,0.0,0.6)
ConvertToYUY2()
ResampleAudio(44100)
Do you have an suggestion on how to keep CCE from crashing?
Below is copy of the logfile.
cce created.
encoder initialized.
>> received encoding start notification
encoding started at 2003/03/21 07:32:46.
>> received encoding stop notification
encoding stopped at 2003/03/21 09:48:21.
sync stopped.
fdev0 closed.
fdev1 closed.
uncompressed YUY2.
cce created.
encoding started at 2003/03/21 09:48:38.>> received encoding start notification
encoding stopped at 2003/03/21 09:48:46.
cce encoding failed: *** Could not write to the file <\\DON\SharedDocs\shared video\movies\the lord of the rings\lord of rings 1\lord2\elor12nb.mpv> ***
The handle is invalid.
[Windows error code: 0x6 6]
sync stopped.
fdev0 closed.
fdev1 closed.
uncompressed YUY2.
cce created.
encoding canceled.
encoding started at 2003/03/21 17:04:46.>> received encoding start notification
encoding stopped at 2003/03/21 17:04:46.>> received encoding stop notification
sync stopped.
fdev0 closed.
fdev1 closed.
>>>> Performance <<<<
Source : 0.042 seconds (1 frames)
Elapsed: 1.656 seconds
>> File reading 0.021 1.254 %
>> Decoding 0.000 0.000 %
>> RGB -> YUY2 0.001 0.041 %
>> MPEG encoding 1.635 98.705 %
fexp thread terminated.
***** Cinema Craft Encoder SP shutting down at 2003/03/21 17:05:09 *****
Thanks in advance,
VCThis is so much fun!
A simple question on Two passes Xvid Encoding,using GordianKnot(not autoGk)
By avengerevenge in forum Newbie / General discussionsReplies: 2Last Post: 26th Jun 2010, 07:46 -
More than 2 passes
By marioval in forum Authoring (DVD)Replies: 6Last Post: 15th Mar 2010, 05:59 -
ConvertXtoDVD encoding passes
By leghorn in forum Authoring (DVD)Replies: 5Last Post: 6th Aug 2009, 07:42 -
CCE SP2 number of VBR passes
By DRP in forum Video ConversionReplies: 1Last Post: 25th Oct 2008, 02:53 -
vbr passes in cce 2.70 sp
By DSLGuy in forum Video ConversionReplies: 1Last Post: 19th Feb 2008, 23:33
