I've recently started preserving my collection of wrestling tapes (all the Monday night shows) and am wondering if anyone else is doing the same thing, or has done so in the past?
My original hope was to put one show (roughly 90 mins without commercials) on a VCD. But tests proved this to just be too awful to look at. Now I'm putting two shows onto a DVD at about 3000 with 112 audio. This looks... eh... tolerable. I'm capturing in DV AVI.
I ask specifically about wrestling since there's so much fast motion in a show that it seems like it would be a different conversion process than a normal television show. Anyone have any settings that they use for something like this?
So, you're saying your tapes have been played so many times that there are bad spots throughout the majority of the tape? Anyway, capturing to DV AVI, nothing wrong there. I use VirtualDub to open DV AVI files from my DVC. You need the MainConcept DV Demo Codec v2.1.0. for VD to recognise them, though. As for the fast motion, I would select DivX Pro v5.0.2 or 3 and as for the bitrate, probably 1000. I usually do a 2-pass operation through Job Control, one pass to scan the video so it can determine the low and fast motion areas to use a higher or lower bitrate and the second pass to do the actual encoding. I hope this will help you. I am no expert though.
"Great Spirits Often Encounter Opposition From Mediocre Minds." -
i've done this. i found however that putting one show each DVD is the best way to go. putting two shows (about 3 hours+ minus the commercials) gives you all kinds of blockiness. use TMPGenc to encode (2-pass VBR) and set the motion search precision to very slow.
(useless fact: capturing the shows live as they air gives 200% better quality than if you record them to VHS first. i guess you know this but for past shows, you can't help it.) i'm wanting to capture WrestleManiaXIX. this is definitely a 2 disc-er.Laserdiscs are cool, but laserdiscs on DVD-Rs are cooler. -
Originally Posted by T-E-M
Originally Posted by monoxide77
As soon as I can get a spindle of recordable DVDs for the price of a spindle of recordable DVDs, then I'll do just that.
Help encoding mp4 with lots of action (wrestling)
By owen316 in forum Video ConversionReplies: 13Last Post: 15th Jun 2011, 09:54 -
Problem converting H264(mkv), keeps crashing while converting.
By weedelf in forum Video ConversionReplies: 4Last Post: 9th Apr 2009, 23:56 -
Converting/examining my video files and converting to have less pixelated?
By SimpleSimon in forum Video ConversionReplies: 51Last Post: 28th Aug 2008, 23:33 -
Converting songs purchased on itunes and converting to mp3
By maroonx in forum AudioReplies: 1Last Post: 23rd Jan 2008, 00:17
