I've been having trouble using a 192kbit j-stereo 44100 Mhz MP3 encoded by LAME 3.93 as the audio in a DivX encoded with VirtualDubMod.
The video seems to encode properly, until it comes to viewing it with DivX Player. It says that the audio format included in the DivX file isn't recognised, yet I've managed to save the same audio format into a DivX with DVDx before.
I've tried both direct stream and full processing mode.
You problably doesn´t have the codec for the movie,try using a program called GSpot to find out if which codec the audio use.
Download GSpot from here:
http://www.headbands.com/gspot/ -
Yet I've managed to properly play back MP3 audio in a DivX with the DivX Player encoded with DVDx.
What would you do if you just saw a lame video?
By KnifeSoldier in forum Newbie / General discussionsReplies: 2Last Post: 25th Jun 2008, 05:23 -
Need a program to combine & cut divx, mpg & wmv
By sync in forum EditingReplies: 3Last Post: 14th Nov 2007, 07:02 -
To lame for HD?
By rhythminmind in forum Media Center PC / MediaCentersReplies: 5Last Post: 10th Oct 2007, 19:38 -
Disappearing LAME option
By koberulz in forum Newbie / General discussionsReplies: 1Last Post: 13th May 2007, 10:19
