Been awhile since I posted, anyways does anyone know of a way to include photo stills when authoring a DVD. I'm using Spruce, but havent really seen a way to do this within the software (still a noob). I'd like to set it up to run like a slide show that you can select from the chapter menu. Is there a way using Spruce, or is there some other software I should be using. Thanks.
There are two ways to do this:
1. Use an authoring software that supports slideshows (Ulead DVD Workshop*, Movie Factory 2, etc.)
2. Name the pictures sequentially (pic001.jpg, pic002.jpg, etc.), then use a program like SWF2AVI to make a movie out of the images, then run the AVI through tmpgenc.
Also, check here for a similar method (using the "video" option for saving) at https://www.videohelp.com/forum/userguides/149567.php
*my personal favorite.
How to Rip Photo Galleries from DVD
By onlyeuro in forum DVD RippingReplies: 6Last Post: 20th Aug 2012, 21:26 -
DVD authoring program that will add Macrovision
By Nolonemo in forum Authoring (VCD/SVCD)Replies: 19Last Post: 31st Oct 2010, 03:26 -
hosted photo galleries w/ embeddable slideshows (flickr, picasa)
By sdsumike619 in forum ComputerReplies: 2Last Post: 1st Oct 2009, 14:17 -
DVD authoring - can I add PDF?
By mheitzman in forum Authoring (DVD)Replies: 8Last Post: 27th Oct 2007, 16:42
