I have eddie murphy delirious.avi and have tried all sorts to get this to play on a DVD player. All the settings i've tried make the audio skip the frames go slow can someone tell me some settings that might work for this. {see below}.
thanks
Your problem is the frame rate: 20 fps is not like any video standard at all!
I'd extract the audio to WAV, then change the frame rate to some standard PAL/NTSC setting with AVIFRATE, and speed up the audio with the same amount. 20->25 fps would require that you compress the audio to 80% of original - may make Eddie sound like Mickey Mouse
/Mats
Going mad trying to demux a TS
By twinaleblood in forum Video ConversionReplies: 16Last Post: 22nd Jul 2012, 13:54 -
confused with avi settings:
By modern saviour in forum Video ConversionReplies: 3Last Post: 4th Oct 2010, 15:52 -
Tmpeg 2.5 will not encode .avi
By WuTangDvD in forum Newbie / General discussionsReplies: 9Last Post: 20th Jul 2007, 14:01 -
AVI to MP4 Audio out of synch!! HELP!! DRIVING ME MAD!!!
By traqman in forum DVD RippingReplies: 7Last Post: 15th Jul 2007, 01:01
