I have a DVDR that has a crappy menu, and I want to make an exact replica (no quality loss) but author a nice menu and chapters. What tools would I need to do this?
Movie Factory 2 won't do it because it won't import AC3--it requires me to take the audio to wav first, and I'm afraid there would be a quality loss. TMPGEnc doesn't output AC3, so I can't use it, either.
What's the easiest/best way to get this DVDR copied and change the menu?
Thanks,
Brian
a) Movie Factory 2 can import AC3 by "replace audio".
b) Other author tools supporting AC3: SpruceUp, DVD-workshop, DVDit-PE, ImpressionDVD, Reel-DVD, DVD-maestro... -
If all you want to do is create a new menu there's no need to do anything with the VOBs containing your main movie. However, the 'easiest' thing to do is generate your menu, then demux the VOBs to m2v + ac3 (eg. smartipper), then re-author everything how you'd like it (eg. DVD Maestro).
I was thinking it would be easiest if I could just import the audio and video directly into my authoring software. Some software, like DVDit! allows that, I believe. What do you think? Can I do that?
Plus, I'd like to keep the audio in AC3 format, and I don't think TMPGEnc outputs AC3.
Merging MPEG2 stream with its AC3 audio... or converting MKV to MPEG2
By cwt in forum Video ConversionReplies: 2Last Post: 5th May 2010, 14:18 -
What do I get for my needs - Mpeg2\Ac3 capture?
By Castor troy in forum Portable VideoReplies: 1Last Post: 20th Apr 2008, 17:56 -
Sync issues after converting AVI (DivX 5/AC3) to MPEG2/AC3
By Greycat in forum Video ConversionReplies: 4Last Post: 25th Mar 2008, 10:24 -
Edit MPEG2 video with AC3?
By Valnar in forum EditingReplies: 6Last Post: 30th Nov 2007, 20:31 -
converting mpeg2/ac3 and avi/ac3 to avi/lambmp3
By corumz in forum Video ConversionReplies: 2Last Post: 17th Sep 2007, 09:32
