When I try to encode SVCD using TMPGEnc, it pop up a error message "The MPEG Encoder is expired". Now, I can't do any encoding on my mpeg2 file - from Hauppauge WinTV PCI - to SVCD. My TMPGEnc is already Beta12j. What should I do now? Thanks!
there is a crack on the net that allows U to restart the counter okay it may say its for an earlier version but it does work... go to http://www.icewarez.net & use the cracks search engine to find it..
icewarez suck's tons of pop up windows just do this it works
Run regedit and find:
HKEY_CLASSES_ROOT\CLSID\{63902277-B101-4049-8B46-C24B67E155E5}
that's what you want to delete:
This will reset the clock back to 0 (have to do this every 30days). Currently there is no way to actually buy TMPGenc.
<font size=-1>[ This Message was edited by: spiderman2k1 on 2001-09-11 09:24:26 ]</font>
which is better Mainconcept MPEG Encoder or H.254 Encoder
By d_unbeliever in forum Newbie / General discussionsReplies: 7Last Post: 4th Aug 2012, 19:14 -
TMPGEnc to License x264 Encoder for TMPGEnc 4.0 XPress
By poisondeathray in forum Latest Video NewsReplies: 17Last Post: 28th Jan 2011, 16:07 -
tmpgenc 4 audio no AAC encoder?
By sychern in forum Video ConversionReplies: 1Last Post: 22nd Jun 2009, 22:06 -
TMPGEnc has expired what do I do?
By Remyisme in forum Newbie / General discussionsReplies: 3Last Post: 20th Oct 2008, 14:55 -
Better encoder than TMPGEnc
By dazza555 in forum Video ConversionReplies: 7Last Post: 15th Sep 2007, 10:45
