Hey guys !
I have one question :
I will buy DVD Burner Sony DRU-500 AX but it will be setup for region 1 right ? ... The thing is that most of my DVD's are region 4. How can i copy them without lock my Burner (i Mean i wish that the burner be able to change regions anytime and several times without lock it)
Is there a solution for this ?
thanks for the help :P
hgtvg
If you live in the US the burner will likely be set to region 1.
Yet I think noone have seen a patched firmware or anything for the DRU-500A/X to make it region free. I don't think there is another option, cos you cannot change the region more than a few times, then it will lock (as you said). Seems likere is no sollution for you at the moment
I wanna be bigger, stronger, drive a faster car...
Need to decode Sony DVD to play all regions
By Rhonda in forum DVD & Blu-ray PlayersReplies: 3Last Post: 22nd Apr 2011, 23:36 -
Regions: Sony DVP-SR90 CD/DVD player
By Marvinshadow in forum DVD & Blu-ray PlayersReplies: 2Last Post: 8th Oct 2010, 12:22 -
Look for DVD player that can change from region 1 to all regions
By plk1758 in forum DVD & Blu-ray PlayersReplies: 5Last Post: 19th Feb 2010, 11:27 -
How to change regions on a DVD or TV?
By SnowStormWolf in forum ProgrammingReplies: 1Last Post: 8th Jul 2007, 18:11 -
Sony Vegas - any free way to import clips/veg files to regions?
By n0id in forum EditingReplies: 0Last Post: 10th May 2007, 17:31
