Hi there,
I've done my first SVCD (w/header trick) in order to play it on my Sony Stand Alone DVD.
I did it frameserving from virtualdub + subtitles filter, Encoded in TMPGEnc. After that, I did cut each MPG file using TMPGEnc and finally did the header trick to each of the 4 new files.
Here is where the question appears.....when cutting the file in TMPGEnc, you have the choice to select the type of file….if I chose “MPG-1 Video-CD (non-standard)” would it be the same that cutting & then multiplexing?....would this be a cutting & header tricking single operation?
Thx for the help.
I don't know if this was a stupid question, or nobody wanted to spend a couple ofr minutes helping me....but, if someone there wants to know...IT WARKED. So you can cut & do the header trick in just 1 pass.
Maybe nobody who had tried it read your post. Anyway, thanks for trying it and posting the results!
8)
"Art is making something out of nothing and selling it." - Frank Zappa -
The problem is that cutting with TMPGEnc produce lack of last 20 secs of sound on the resulting files.
That can happen when cutting mpegs. I always use the source range function, and I batch encode to avoid cutting.
8)
Trick PSP video
By jntaylor63 in forum Video ConversionReplies: 0Last Post: 4th Aug 2011, 09:42 -
covert avi header to mpeg header
By nidhi in forum Video ConversionReplies: 6Last Post: 29th Jul 2010, 19:40 -
wireless Networking (router trick)
By stiltman in forum ComputerReplies: 0Last Post: 25th Mar 2009, 23:18 -
Help Nero is not doing the trick
By breeze9 in forum Authoring (DVD)Replies: 6Last Post: 1st Feb 2008, 08:36 -
Is there some trick to putting in a video card?
By videobread in forum ComputerReplies: 12Last Post: 21st Jun 2007, 21:07
