I'm thinking of purchasing this card since it's the cheapest
one around and has s-vhs (other choice being Hauppage Wintv Go)
I was wondering if I can get a higher capture resolution than
352 x 288 in a Pinnacle if I use the Btwin drivers ? Since
I read it works for Hauppage's Wintv ..and they are
as far as I know based on the same chipset bt8x8 :S or similar
howe did you get resolutions so high on this card?
also, what do you use to get past the 71/36 minute wrap around? -
Sorry, that's for still captures. What I mean is, it gives me the option to save at that res, whereas with DScaler, it's only 768 by whatever.
Software for Pinnacle PCTV usb2
By jodal in forum Media Center PC / MediaCentersReplies: 11Last Post: 28th Apr 2010, 06:32 -
pinnacle pctv 310i
By marc21782000 in forum Capturing and VCRReplies: 10Last Post: 4th Jan 2010, 03:30 -
What software for Pinnacle PCTV HD?
By tomreedtoon in forum Capturing and VCRReplies: 10Last Post: 9th May 2009, 07:14 -
Pinnacle PCTV USB 2 - Vista
By hellybelly in forum Capturing and VCRReplies: 0Last Post: 30th Oct 2007, 04:20 -
PCTV Rave Card - trouble capturing xbox + tv audio
By chocolate_brownie in forum Capturing and VCRReplies: 2Last Post: 24th Jul 2007, 09:38
