  1. Hi,
    I have captured 2 hrs of VHS into AVI format with Huffyuv compression.
    I have splited the AVI file into 5 of 4gb each.
    I want to make the VCD from this. what is the best way.
    1. Using Virtualdub to frameserve to TMPGenc of all the files
    OR
    2. Convert the individual file ( AVI ) to MPEG1 using TMPGenc, then add all the file ( mpeg ) for vcd authoring. If i do this way will my video will be continues.
    Thanks,
    Mursand
  2. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Joining mpegs can be a pain (don't think I've ever succeded 100% - sync problems galore!). There's no disadvantage neither quality nor timewise in frame serving, so I'd take that route!
  3. Thanks mats.
    Thanks,
    Mursand
