I just tried the trial version of movie factory 2 and It is great!! for making dvd episodes. After you decrypt your movie you open movie studio and select import dvd. Then it will show you each episode and you select which one you want. It will then take the episode you selected and create a mpg file with it. You can then use any authoring software to make the dvd or just use movie factory (I prefer sonic foundry dvd archtect, more control over menu) Also in movie factory preferences you can change the quality of the mpg you create out of your dvd.so you can fit all on one dvd if you want to.[/img]
Results 1 to 1 of 1
Ulead DVD Movie Factory 6 Plus
By orientaldragon in forum Newbie / General discussionsReplies: 8Last Post: 2nd Apr 2011, 09:48 -
By Ragamuffin in forum Authoring (DVD)Replies: 3Last Post: 6th Oct 2009, 13:22 -
Ulead DVD Movie Factory...
By mmitchell_houston in forum Authoring (VCD/SVCD)Replies: 225Last Post: 23rd Oct 2007, 11:59 -
By koberulz in forum Newbie / General discussionsReplies: 10Last Post: 26th Jun 2007, 08:14 -
Ulead DVD Movie Factory 5 Plus Help
By sootylfc in forum Authoring (DVD)Replies: 3Last Post: 21st May 2007, 19:20
