If I record a show from VHS then turn it into a mpeg file can I put it on a DVD-R?
If I can , does it create vob files for it?
Thanks.
If everything is infinite then nothing is definite.
I would suggest you read a few guides. To create VOBs you will need a DVD Authoring program that will will convert your MPEG file to VOBs with the standard DVD structure (Ulead DVD Movide Factory is one of the best entry level DVD authoring programs). If you don't want menus then you could use IFOEdit which is freeware and has basic DVD authoring.
What guide will teach me how to take an mpeg1 or mpeg2 file and turn it into VOB files?
If everything is infinite then nothing is definite. -
Have you not ever explored this web site other than the forums? This site has a section called How To and one of them is called Author
https://www.videohelp.com/author
Best UK PAL VHS / D-VHS machines for digitising old VHS tapes
By pauldsc in forum RestorationReplies: 8Last Post: 6th Jan 2012, 10:21 -
How to convert a PAL VHS into NTSC VHS or DVD?
By coody in forum Video ConversionReplies: 9Last Post: 22nd May 2011, 03:09 -
VHS to DVD - LongPlay VHS Problem
By zanzi81 in forum Capturing and VCRReplies: 14Last Post: 1st Feb 2010, 02:56 -
VHS Copy Protection when using a Dual DVD\VHS Unit
By wizer in forum Capturing and VCRReplies: 1Last Post: 20th Sep 2009, 15:25 -
NTSC VHS to PAL DVD Via DVD VHS Combi
By wozmac in forum DVD & Blu-ray RecordersReplies: 7Last Post: 6th Jun 2007, 02:16
