Can anyone comment on the quality that the Canopus ADVC converter can produce from VHS or Digital Satellite?
To my understanding both the ADVC 100 & the ADVC 500 use the proprietary DV codec from Canopus. Will this mean that the converters resolution/bitrate will be locked? What is the bitrate that the DV codec uses, and dose Canopus use a standard or non-standard bitrate?
I would love to see some motion samples or screen shots!
TIA
I use an ADVC-100 to capture from DirecTV, quality is outstanding. It's not as proprietary as you think it is, in fact I generally wind up using the Microsoft DV stuff and it's all happy. Having a small problem right now getting iuVCR to cooperate, but my MPEG2's and my burned DVDs of my DirecTV captures are fantastic.
I typically capture to .avi then edit and re-encode as MPEG-2, but the direct MPEG captures are awesome. I just don't like commercials. 8^)
Can I use a U.S Canopus ADVC-100 in the U.K?
By jedi55 in forum Capturing and VCRReplies: 33Last Post: 6th Oct 2012, 19:26 -
Canopus ADVC-100 - noisey/grainy and scaling?
By Gibson's Squares in forum Capturing and VCRReplies: 4Last Post: 2nd Jun 2011, 15:41 -
Canopus ADVC-100 vs Canopus ADVC-110
By tarrickb in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 20Last Post: 16th Oct 2010, 21:52 -
Microsoft DV Camera and VCR/ Canopus ADVC 100
By BonnieW88 in forum Capturing and VCRReplies: 0Last Post: 27th Feb 2010, 18:26 -
Canopus ADVC-100 outputs
By datman in forum Capturing and VCRReplies: 2Last Post: 7th May 2007, 19:24
