Some of the VOBs either have no sound, or some have sound but are in spanish. All are dual layered, I've been told that using Ifoedit, should solve this problem with the ifo, but I've never used this program before and am not even sure if this will help? I've looked at ifo guides, but was wondering if someone could tell me exactly in general terms what I need to do to get the audio corrected?
Ifoedit should work. There's a guide at http://www.doom9.org/mpg/ifoedit-menustripping.htm on how to do it. If it still comes out in spanish or no audio, try checking the FPU point, you'll know what I mean when you get there. Thanks to Vejita-sama for the website.
If everything is infinite then nothing is definite.
VOBs burned to DVD have sound missing on TV (but play OK on PC)
By martinlest in forum Authoring (DVD)Replies: 3Last Post: 29th Mar 2012, 07:17 -
Having a problem with some vobs - audio, no video.
By architectofpain in forum Software PlayingReplies: 2Last Post: 24th Dec 2008, 10:41 -
Convert non-compliant VOBs to "good VOBs"
By pmolson in forum Video ConversionReplies: 3Last Post: 24th Oct 2008, 11:52 -
no audio in .vobs
By UncleBose in forum DVD RippingReplies: 2Last Post: 7th Oct 2008, 16:51
