I have a .avi file I'm trying to convert to mpeg using tmpg. Everytime I convert it the video doesn't have any sound. I've loaded the file in gspot and it says that I have all of the encoders. How do I get the sound to work as an mpeg file? Gspot says the audio is in a .asf format. Please help. Thanks
Results 1 to 11 of 11
ASF format? I've never run into that one. Try extracting your audio with VirtualDub. Set the AUDIO option to "Full Processing" mode. Select FILE | SAVE WAV. You should be prompted to supply a filename. Just give it a .WAV extension (example: extract.wav ). Plug that WAV file into TMPGenc as your audio source.
Impossible to see the future is. The Dark Side clouds everything... -
hi!
you might want to convert the audio using graph-edit.
afaik. ASF is a container-format, not a stream-format.
however.
what i know for sure is that it's an microsoft-thingie.
bye,
--hustbaer -
dude i wrote a doc explaing how to create a vcd of a movie on 1 cd
www.data-uca.150m.com/vcdencoding.doc
hopefully it will help if not let me know
as this is the easiest methid ive found to encode
what you might be getting in vdub when you load up the avi is "blah blah is a lttle outand might creat sync problems blah blah", thats becuase the avi has to be decompressed 1st
read me doc, it explains it better there -
You should also get the latest version of VirtualDub (1.4.13 I think).
I just downloaded virtualdub 1.5.1. When I save the file as wave it still doesn't work. Whats wrong? Thanks
well, extract the audio track maybe?
is't hard to explain but not really that hard to do.
just look for some graph-edit guide, there are plenty!
bye,
--hustbaer
adding subtitles isn't working anymore
By kategabrielle in forum ffmpegX general discussionReplies: 3Last Post: 26th Jun 2010, 05:36 -
HDTV to DVD isn't 16:9
By sambat in forum Authoring (DVD)Replies: 4Last Post: 6th Apr 2009, 16:54 -
AC3 on m4v not working, 48KHz AAC not working, 44.1KHz does?!?!
By dmjerbear in forum AudioReplies: 14Last Post: 11th May 2008, 19:23 -
Isn't this annoying?
By Midzuki in forum FeedbackReplies: 17Last Post: 4th Feb 2008, 13:34 -
Vista DVD Maker (isn't working)
By naomi c in forum Newbie / General discussionsReplies: 3Last Post: 3rd Aug 2007, 05:30
