can someone tell me how to fix bad frames in vdub pls?
If you get a VBR audio warning when you load the Avi in Vdub, then you must use Vdub-MP3. Here's the guide: https://www.videohelp.com/forum/viewtopic.php?t=142555
If you don't get a warning then you can use regular Vdub. Load the Avi, under Video select Scan Video Stream for Errors. If it reports bad frames then select Audio-Direct Stream Copy, Video-Direct Stream Copy, Save Avi. A new file will be created without the frames masked off by Vdub.
Good luck.
"Art is making something out of nothing and selling it." - Frank Zappa -
Regular Vdub cannot handle an Avi with audio encoded using Variable Bitrate (VBR). Some movies have VBR-MP3 sound and Vdub will give a warning when you load it up, you can't miss it. If you get the warning, then just use Vdub-MP3 and follow the guide.
VirtualDub - fixing bad frames with blending and without re-encoding
By spicediver10191 in forum Video ConversionReplies: 3Last Post: 11th Apr 2012, 09:15 -
Fixing [D] Frames?
By Startropic1 in forum Video ConversionReplies: 1Last Post: 9th May 2010, 12:03 -
fixing bad frames
By vidclip in forum Newbie / General discussionsReplies: 2Last Post: 10th Jan 2010, 16:00 -
Problem Fixing corrupted frames
By Blå_Mocka in forum Newbie / General discussionsReplies: 6Last Post: 13th Nov 2007, 09:44 -
Fixing bad tracking
By J C in forum RestorationReplies: 11Last Post: 7th Sep 2007, 08:11
