I have used Tmpeg and Ulead to convert but they have not worked for recent files. Any suggestions on a new program that has come out or is there a better version than tmpeg 2.58.44.152
I am trying to convert insomnia part 1. Its split up in to two parts. The audio is ac3 and i have the codec for it. I have a codec for both the audio and the video, but have nothing that will convert it. I have tried converting audio with vdub and then put it in tmpeg. Tmpeg keeps freezin on me. I am really frustrated i have tried everything.
Best Encoder is CCE and best program for filtering and resizing Avisynth. It is not plug and play solution. But result will be outstanding. CCE now avalible Basic version only 58$. Avisynth fre software. Use Besweet with Besweetgui (last version) for get audio from Your *.avi in *.wav and separately load *.wav in TMPEGEnc.
Yury. -
I use TMPGEnc, Vdub, FlaskMpeg, and Gsopt while convering my movies, but i usually only use TMPGEnc.
Time's not wasted when you're wasted all the time.
64 bit encoding program for MKV to MP4
By prk72 in forum Video ConversionReplies: 10Last Post: 30th Oct 2010, 14:11 -
Program to crop MP4 files without re-encoding
By milatchi in forum Video ConversionReplies: 3Last Post: 20th Aug 2010, 10:13 -
Program to split .mov files without re-encoding
By Guest in forum EditingReplies: 5Last Post: 21st Jul 2010, 20:09 -
Free Program For Creating Chapter Points In DVD Video Without Re-encoding?
By bbanderic in forum Authoring (DVD)Replies: 3Last Post: 7th Mar 2010, 09:17 -
SUPER converter program has Encoding Failure Error
By kerrex_2006 in forum Video ConversionReplies: 4Last Post: 26th Sep 2009, 13:44
