Hey all,
I hope this isn't the wrong forum for this... ;^)
Here's my problem: I copied some video from my Sony camcorder using Adobe Premiere. It made a 10 GB AVI file that seems to play fine if I open it in Windows Media Player. The problem is, I need to convert it to DivX and Virtualdub won't open it. It gives me an error saying: "Couldn't locate decompressor for format 'dvsd' (unknown) VirtualDub requires a Video for Windows (VFW) compatible codec to decompress video. DirectShow codecs, such as those used by Windows Media Player, are not suitable."
Now, I installed a VFW codec and that didn't seem to solve the problem, so I'm kind of stuck...
As for the file, this is what GSpot gives me:
FourCC: dvsd
Codec: Sony Digital Video (DV)
Vendor: Sony
Status: Codec NOT installed
Anyway, any help would be greatly appreciated!
Thanks in advance,
filefreak
If you can open it in TMPGEnc, do so. Select File-->Output to file-->AVI. when the requester opens, select Video setting and select the appropiate DivX codec. Name the file and save it.
Hello. -
Filefreak, you need MainConcept DV Demo Codec for VirtualDub to open your DV AVI files.
http://www.mainconcept.com/archive/DVDemoCodec_v2.1.exe"Great Spirits Often Encounter Opposition From Mediocre Minds."
converting Divx to QT?
By rotuts in forum MacReplies: 3Last Post: 17th Jul 2008, 17:28 -
Converting Divx w/ Vorbis audio to Divx w/ MP3
By tachyon2u in forum AudioReplies: 3Last Post: 24th Feb 2008, 00:35 -
Converting DivX to HD
By CFCproductions in forum Video ConversionReplies: 6Last Post: 18th Jan 2008, 15:11 -
Converting HD (DivX/MOV/WMV etc) to DVD or DivX ???
By snadge in forum Video ConversionReplies: 32Last Post: 8th Jan 2008, 06:48 -
converting HDV to DIVX
By galbertse in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 8Last Post: 14th Nov 2007, 10:56
