ok here is the deal...it took me a lot of experimenting to get XVIDs to play on my machine in the first place. i tried different combinations of Nimo, Xvid, and Divx codecs, however, the ONLY thing that worked was uninstalling all of those and using only ffdshow. Unfortunately, i am in need of cutting a select XVID. I used to use virtualdub for DivX but now i cannot get it to work with XVIDs. i receive a message that says:
"couldn't locate decompressor for format XVID (unknown). VirtualDub requires a Video for Windows (VFW) compatible codec to decompress video. Direct Show codecs, such as those used by Windows Media Player,
are not suitable."
In an attempt to remedy this i installed the XVID codec in addition to the ffdshow...this made the sound but not the picture work on all XVIDs. Is there another tool to cut XVIDs that might work with my codec situation.
Try downloading the Nimo Codecs Package as that comes with a XvID codec and decompressor. NCP is in the Tools Section to your left under Codecs.
http://www.roeder.goe.net/~koepi/xvid.shtml
First link >>>XviD-04102002-1.exe
tis all you need for xvid
That link ^ should allow you to.
If not, try installing the 'VFAPI Reader' in the tools section on this site under 'other useful tools' -
yeah, i tried that with Nimo, however, it did not work....i can get XVIDs to play...but i want to cut them. what i am trying to figure out is whether i can cut the files with a different program then virtualdub.
VirtualDub/Xvid question: YV12 vs. XVID FourCC in the xvidvfw.dll driver???
By KneeRow in forum Video ConversionReplies: 14Last Post: 1st Aug 2010, 13:35 -
Does xvid cli (command line version of xvid) actually exist ?
By vhelp in forum ProgrammingReplies: 10Last Post: 29th Oct 2009, 14:18 -
cutting the end of xvid file
By eric123 in forum EditingReplies: 1Last Post: 29th Jan 2009, 14:13 -
Weird I don't have XviD or DivX codec installed but I can see Xvid movies
By Talayero in forum Software PlayingReplies: 4Last Post: 5th Jun 2008, 11:47 -
Convert mpeg-2 to xvid while cutting commercials...
By swishbish33 in forum Video ConversionReplies: 5Last Post: 25th Oct 2007, 18:10
