Will a MiniDV cassette without a memory chip produce a recording with a timecode?
<font size=-1>[ This Message was edited by: herbardee on 2001-09-11 02:22:29 ]</font>
Just about any digital video camera, be it MiniDV or Digital8, should produce a timecode. Follow this procedure, called striping, and it should be okay: Put your MiniDV tape in the camera, then, making sure that the lenscap is still on, put the camera in record mode, just like you were videotaping something. Let the camera record all the way to the end of the tape. It's as simple as that. The net effect will be that you've just taped an hour's worth of black, but the tape will be striped. Then just rewind the tape and you're ready to go. If you do all your blank tapes this way, you can do batch capturing in Premiere.
Editing .sub timecodes?
By Odaik in forum SubtitleReplies: 5Last Post: 27th Apr 2012, 17:00 -
M4V Timecodes?
By Penumbra in forum Video ConversionReplies: 5Last Post: 2nd Apr 2010, 17:21 -
DVD Subrip shows incorrect timecodes !
By Chainsaw_1 in forum SubtitleReplies: 2Last Post: 31st Mar 2010, 19:28 -
extracting timecodes from hardcoded subs
By quzma in forum SubtitleReplies: 0Last Post: 2nd Jan 2010, 16:26 -
DV to AVCHD (or similar formats) and keep timecodes
By tmorrow411 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 23rd Jan 2009, 07:17
