  1. I am hoping this has happened to someone else to see if there is a fix.
    I use tmpgenc and have a movie that was converted to PAL...actually it was PAL before...
    It works great on computer..audio is in synch.
    When I burn it with NERO and play on dvd player..
    the audio will be OUT of synch...If I turn off my dvd player and turn back on...the audio will be PERFECT.
    My dvd player is pioneer 434...I posted here because I am thinking it might be NERO but I am not sure.
    I have an external cd burner and vcdeasy does not recognize it and movie factory says its not the right format and wont open it so I dont have anything else to try.
    Does anyone know what might be causing this?
  2. well did you extract the audio from the movie using Virtualdub and add it with TMPG ?
    You have to turn all audio compression off because that may be the problem.
