I'm using bbMPEG, IFOEdit, and ImgTool. When I try burning my DVD in ImgTool it complains that the "VIDEO_TS.VOB" file is missing. Obviously it is as my main video is the "VTS_01_1.VOB". It says that without a "VIDEO_TS.VOB" that the DVD might not be playable. I've tried DVDs made without the "VIDEO_TS.VOB" on many players and it seems to work fine. Is this really an issue? If for some players it is a problem then what do I do to resolve this? Do I make a MPEG2 video with a few frames of black and author that into a VOB and put it in the VIDEO_TS directory? The "VIDEO_TS.VOB" is the video played first, right? Thanks!
Use DVDToolbox.
It has a Create VIDEO_TS.IFO selection, but you are correct this is NOT needed. Its usually used for the stupid FBI warnings / studio logos. Dont sweat it, its just extra garbage, uless you want to make one and put a small intro clip in there.
VidHack
WebEx WMV file, can't open in VirtualDub, says "missing codec"
By violetta in forum Newbie / General discussionsReplies: 13Last Post: 22nd Jul 2016, 22:39 -
Quality problem "caused" during "deinterlacing" ?
By Hombre_86 in forum DVD RippingReplies: 26Last Post: 25th May 2010, 22:28 -
DVD Architect 4.5 missing "Insert: Submenu from file"
By sir_rob in forum Authoring (DVD)Replies: 1Last Post: 1st Aug 2008, 12:39 -
User info missing in "Review Thread" when composing a reply.
By gadgetguy in forum FeedbackReplies: 2Last Post: 26th Apr 2008, 19:16 -
Make menu for "VIDEO_TS" folder (files inside it)...
By Chana1 in forum Authoring (DVD)Replies: 18Last Post: 24th Jul 2007, 09:29
