I'd like to hear opinions of this program. I look for the following capabilities:
-Most important: stability and reliability (no bugs!)
-Flexible DVD menu creation (Ulead DVDWS is the best example here)
-Ability to create slide shows: Import several pictures (preserving aspect ratio), add transitions, some texts, backgroud music (you know I want to create family albums on DVD)
-Mpeg1 Layer2 audio (not LPCM audio!)
-Import: AVI, MPEG1 or MPEG2 (mpg files, or m2v and separate audio)
Thanks!
If re-call rigth I think PowerDirector dose both LPCM and MPEG1 Layer 2
Final cut express vs. videostudio pro x2 and cyberlink powerdirector
By maverickluke in forum MacReplies: 1Last Post: 9th Apr 2010, 10:08 -
Audio problem with Cyberlink PowerDirector.
By GangstaRap in forum EditingReplies: 4Last Post: 19th Dec 2009, 23:06 -
about saving file in cyberlink powerdirector
By admirer in forum EditingReplies: 3Last Post: 15th Apr 2009, 10:30 -
I have a question about cyberlink powerdirector 6.
By ingeborgdot in forum Authoring (DVD)Replies: 4Last Post: 3rd Nov 2007, 21:31 -
Fed up with Cyberlink Powerdirector - Can you help me choose something else
By gayclarke in forum Authoring (DVD)Replies: 5Last Post: 9th Jun 2007, 22:09
