Can I capture digital cable signals directly to vcd format using AIW Radeon? Digital cable is already Mpeg2 so will the card convert it to mpeg 1? Will the quality be any better than from a coaxial cable? Thanks
you can capture anything to vcd format with radien and a fast processor
Right click the video window>settings. under digital VCR choose video CD as the quality setting. i twill capture VCD ready mpg.
If you want to see what I've done with my videos,
check out my video work on youtube, http://www.youtube.com/user/duhmez/ -
The DC signal is compressed in MPEG-2 (I have Time Warner here), but unfortunately, the stream is decoded and is converted to analog by the time you get it out of your cable box. So to answer your question, yes you will be re-encoding it into MPEG-1 (or 2), but you'll be coming off of an analog stream (even though it started out digital). It will still be a bit better than a cap coming off of regular analog cable though b/c the high frequency rolloff that occurs w/ regular RF cable will only occur from the box down (and not from the street feed down).
What Product to buy to view DIGITAL cable TV on my PC?
By trighap in forum Newbie / General discussionsReplies: 4Last Post: 27th Nov 2011, 17:48 -
Get digital cable into windows media center
By Simoyd in forum Media Center PC / MediaCentersReplies: 12Last Post: 17th Nov 2008, 10:50 -
digital cable = the new svcd format?
By mazinz in forum DVB / IPTVReplies: 38Last Post: 8th Jul 2008, 02:22 -
DVD recorder + digital cable question
By bigkromedogg in forum DVD & Blu-ray RecordersReplies: 3Last Post: 27th Sep 2007, 11:34 -
They want to sell me DIGITAL cable
By Faustus in forum Off topicReplies: 4Last Post: 11th Jun 2007, 10:03
