Here is what Im trying to do with SVCD video authored to a DVDR (patched header trick+reencoded audio trick).
I have many small music video svcd mpegs's but some are PAL and some are NTSC. In Ulead DVD Movie factory it only lets me choose 1 for making a DVD iso else I think it tries to reencode the video to make it all NTSC or all PAL.
When I authored SVCD's the mix of pal and ntsc video was fine in VCDCEASY as my dvd player is able to adapt to this change. But making a real authored dvd is another story.
Is it possible at all to have PAL and NTSC video on 1 dvd like with SVCD?
AFAIK, this can't actually be done. You could try using DVDpatcher to 'convert' the PAL files to NTSC (or vice versa) and see if you can get them accepted by MovieFactory. They may not play right though.
DVD players that play PAL & NTSC - do you need a PAL television?
By ibzomie in forum Newbie / General discussionsReplies: 9Last Post: 12th Dec 2010, 20:53 -
PAL & NTSC in the same camcorder
By griffmedia in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 24th Feb 2009, 11:55 -
PAL VCD -> NTSC Video for NTSC DVD Authoring!!
By Mickey79 in forum Video ConversionReplies: 5Last Post: 12th Aug 2008, 11:30 -
PAL to NTSC - when do i select this option whilst editing & dvd authori
By johnnybravo in forum EditingReplies: 6Last Post: 24th Jul 2008, 10:23 -
Portable NTSC & PAL TV?
By Disco Makberto in forum Portable VideoReplies: 12Last Post: 14th Nov 2007, 22:31
