  1. I am having a bit trouble with a movie.
    I checked in Vdub for bad frames, there was none reported.
    I encoded in TMPGEnc with no problems.
    I played it back in Windows Media player no problems
    Then I burned as a VCD.
    When I played the CD back about half way through it started intermitently breaking up and pops and whistles.
    I then tried playing it back in PowerDVD, it had the same problems. In fact PowerDVX froze up at the same spot.
    I would like to know if there is anything I can do to repair the mpg file?
    jack
    Apr 2002
    Ireland
    did you use the vcd template with tmpgenc?
    if so then it must be a burning/media problem. what cd-r media did you use?
    what speed did you burn the disc at? try burning your cd-r's at a lower speed. because some dvd players have problems playing discs burnt at high speeds.
  3. Yes I used the VCD template, the media is Maxwell and I burned in Nero at 4*.
    jack
    Apr 2002
    Ireland
    oh, i forgot...
    try vcdgear:
    download it from: http://www.vcdgear.com/
    it can repair damaged mpeg files
