hi
would like to flash firmware from 1.00 to 1.30 directly without 1.21...
CAN I DO IT ? IS IT A PROBLEM?
And is it really advantage to flash it if I will be burning ritek G03 at 1x.
Pioneer says writability improvement on 1.30 but can we really see it?
thanks for help guys
i think you should be able to flash directly to 1.30, the firmware flash program is quite easy to use. should not be a problem there.
g03 will still burn at 1x after flashing to 1.30, so i think there's not much difference in your case.. may as well not bother. i flashed mine to 1.30 and it did not seem to help in anyway. -
what happens normally when you flash is the first rom that was installed is full erased and then the new rom is installed. No overwriting of numbers or anything just a full on swap of file's. So of course it wont need 1.21 in order to upgrade since all the code needed is in the rom
Pioneer DV-220V-K firmware
By totonionio in forum DVD & Blu-ray PlayersReplies: 2Last Post: 18th Apr 2013, 09:45 -
Pioneer DV-S838A firmware
By zhudinglong in forum DVD & Blu-ray PlayersReplies: 0Last Post: 21st Jul 2011, 02:12 -
Pioneer DVD recorder firmware
By jh76 in forum DVD & Blu-ray RecordersReplies: 1Last Post: 11th Apr 2009, 03:03 -
Pioneer DVR-216 and Firmware
By dqtus in forum DVD & Blu-ray WritersReplies: 5Last Post: 27th Mar 2009, 03:26 -
Illegal Disc Error w/Pioneer DVR-105 in Nero
By Quadzilla in forum DVD & Blu-ray WritersReplies: 2Last Post: 20th Aug 2007, 13:23
