When trying to put Behind Enemy Lines onto a dvd+r, after using DVD Decrypter, I get no sound on some VOBs, and others I get spanish? It's a dual layer dvd so I just use dvd decrypter to get the movie itself, and it take VOB 04_1 to 04_6 or something like that. Why is it giving me spanish and other times no sound at all?
once the dvd was ripped to the drive U need to use ifoedit to correct the structure of the vobset... open ifo edit, select the ifo of the main set (create a new video_ts dir 1st) the go to vob extras & set up all the check boxes exept remux & strip ids & got to ok! U can leave in the subs if U want. Once all this is done open up your new ifo of the vobset U have created then get the vts sectors & exit the program. U can now burn your disk & it will work ok..
Kev!
(if U cant understand this look up some of the ifo edit guides as they have pics) -
Please say all the software you use what software do you use to encode? I would rip the hole movie and use DVD2ONE or Instant Copy 7
Weird lines show when playing DVD
By tlafo in forum DVD RippingReplies: 1Last Post: 28th Feb 2011, 00:31 -
Horizontal Lines Appear In DVD
By Mark-Leon in forum MacReplies: 33Last Post: 17th Oct 2010, 10:23 -
mp4 to DVD with Nero 7 gives diagnal lines
By johnharlin in forum Newbie / General discussionsReplies: 3Last Post: 12th Mar 2009, 19:07 -
DVD conversion to MKV ...... getting lines in between
By maass in forum DVD RippingReplies: 5Last Post: 20th Feb 2009, 22:44 -
Lines across DVD picture...
By xichael in forum Newbie / General discussionsReplies: 2Last Post: 2nd Sep 2008, 07:36
