I just converted IMAX.The.Greatest.Places.(1999).DVDRip.DivX-QiX.ShareReactor.avi to mpeg using tmpgenc plus. When I play the mpeg file theres no sound. I first tried using virtual dub to make a wave file but the program wouldn't work. I then used avi2 to extract a wave file from the movie succusfully. Then I went back the tompenc and loaded the movie (avi file). I tried loading the wave file with it but it didn't let me. It said that it wasn't supported. Do you know what the problem is? Thanks
The video may have an ac3 audio track. Download gspot from the tools section on the left. Load your avi file into it, and it will analyze your movie and tell you what type of files both video and audio are in it. If it is an ac3 file there are instructions on this site on how to handle them amd how to convert them to viable wav files tmpg will recognize. I'm not sure if avi2 will do the trick.
How to make audio / video business card and website audio/videos clips
By tmh in forum Newbie / General discussionsReplies: 6Last Post: 4th May 2011, 12:25 -
ASF2VC1 & transcode the audio WMA to AC3, then mux video VC-1 and audio
By tigerb in forum Newbie / General discussionsReplies: 0Last Post: 9th Jan 2010, 09:02 -
How to combine video with audio file and replace audio with video files ?
By designbuyers in forum Newbie / General discussionsReplies: 2Last Post: 8th Feb 2009, 12:12 -
Syncing spearate audio/video: Better to stretch/shrink video than audio?
By stantheman1976 in forum EditingReplies: 15Last Post: 16th Jan 2008, 05:14 -
Converting an AVI video with AC3 audio to an AVI video with MP3 audio
By rijulHKG in forum AudioReplies: 1Last Post: 15th Jul 2007, 01:23
