i have a couple mp3_file('s) they play fine in wmp,but i cant add them to a play list.
so how do i change mp3_file to mp3 audio?
winxp
wmp8
there is no such thing as a difference between mp3 file and mp3 audio. maybe its not an mp3 at all.
all i know that in the properties it shows 'mp3_file'
also it wont play in realone player -
This may sound simplistic but have you tried changing the extension to .mp3?
If that doesn't work you might ask/search this question in:
www.hydrogenaudio.org -
can you tell me how to do that? i have used computers a few years and i no idea how to do that.Originally Posted by MOVIEGEEK
earlier today i tried to convert it with headAC3he,but it couldn't see the file.
well now i just tried besweet
it saw it as 'mp3_' and i converted to mp3.
it came out showing 520kbp/s and showing 1:12,but at least it works now. -
Make sure that under the options in Windows, you have the 'show extension' tab ticked. That means you can see like '.exe' or whatever at the end of the file.
When that is done simply select the file you want to change to MP3, then hit F2 and change the name from like "britney spears - oops i did it again" to "britney spears - oops i did it again.mp3" -
You cold always try to re-encode it to .mp3 using a mp3 encoder, such as Lame or Bladenc. I've had to do this a few times before.
Lame MP3 (or any MP3) in Sony Vegas 7
By boom731209 in forum AudioReplies: 7Last Post: 28th Oct 2010, 17:13 -
Trouble converting AVI(divx)+MP3 to FLV+MP3
By BLboy in forum Video ConversionReplies: 7Last Post: 21st Jul 2009, 05:36 -
how to convert MP3 vbr to MP3 cbr?
By sumeshkri in forum AudioReplies: 2Last Post: 26th Aug 2008, 00:59 -
VirtualdubMod: DivX and vorbis aduio -- result file has no audio
By cheerful in forum Newbie / General discussionsReplies: 2Last Post: 27th Aug 2007, 02:27
