    Feb 2003
    UP IN IT (ask your mom)
    I recently installed Ahead NEROVision and upon authoring my first DVD, discovered a slight problem. NO SOUND! I tried several things to remedy the situation, but in desperation, finally emailed the tech department of the software manufacturer. Three to Four weeks later, I finally got a response. Nothing beats punctuality! Apparently, some of the versions went out missing a .dll file. The good people at Ahead sent me a copy of this file, called "NeroMediaCon.dll". I installed it, and now everything works fine. I found that encoding with TMPGEnc and authoring with Ulead MovieFactory2 produces a much higher quality DVD as a finished product. But, if you've experienced the same problem and need the .dll file, I'd be happy to forward anyone the email that Ahead's tech department sent me.
    Best Wishes
    F-ING HOSTILE
    [Insert own retarded quote here]
    Jan 2003
    I sure would like that file!
    michaelinsweden@hotmail.com
    thanks!
    Feb 2003
    Swede- I just forwarded you the e-mail. Let me know if the attachment came through intact! Thanks!
  4. Member SHS's Avatar
    Oct 2000
    Vinita, Oklahoma
    F-ING HOSTILE yes good tool but it only dose LPCM encoding which suck up disk space cutting time in all must half vs MPEG1 Layer 2.
    Did install the latest ver 1.0.4.6?.
    Feb 2003
    Hi- Yeah I was using 1.0.4.6. It seemed easy to use (once I could get the audio to work), but I wasn't too happy with the quality of the finished DVD.
  6. Member SHS's Avatar
    Oct 2000
    Vinita, Oklahoma
    F-ING HOSTILE when have some time email to me I been meaning to try new ver but haven't had time thank.
