Do you guys know any soft that can create thumbnails of mpg-2 files ?
Power DVD (and I think WinDVD) has a feature that allows you to capture screenshots from within the player, does this help?
Ok, but it do it once at a time. I would like to find one to create from a lot of files, many ones, automatically.
i haven't tried this, and it may sound stupid, but it just might work...
start up a program that can load and process many different files sequentially (videomach or whatever)
set framerate extremely low (aka the intention is to drop most of the frames)
if the program supports it, have the result saved to multiple independent images, if not, just save it to an avi and then use something else to convert the (short very fast) avi frame by frame to images
it's just an idea...... this copy of me hasn't been registered for the last 36 years! (no spamming please)
Free software to split large MPEG-PS file into many small MPEG-PS files?
By videonewbie22 in forum Newbie / General discussionsReplies: 9Last Post: 5th Jul 2018, 19:16 -
How to create chapter menu without thumbnails
By truongv0ky in forum Authoring (Blu-ray)Replies: 3Last Post: 4th May 2011, 15:05 -
thumbnails for m2ts files
By runLoganrun in forum Software PlayingReplies: 2Last Post: 8th Dec 2008, 13:37 -
How to create small clips from a movie!
By unstopabl3 in forum Newbie / General discussionsReplies: 3Last Post: 27th Dec 2007, 04:34 -
DVD won't read...won't create avi thumbnails
By ru5ty in forum DVD & Blu-ray WritersReplies: 6Last Post: 27th Jul 2007, 20:04
