Just bought the Pioneer A05 and opened up my PC to discover that all of my plugs coming from the power unit are in useIs there something I can get similar (in theory!) to a household gang socket to give me an extra plug? If not any other suggestions appreciated (except unplugging my CD Rom & Writer :P
Many thanks
i think there are adaptors out there but this should not be the main concern. the main thing i would worry about is the actual power supply. you may not have enough power to run everything that you want and will probably need to upgrade it to a larger power supply. someone correct me if im wrong.
Peter H -
Just look for something called a Y adaptor. It only costs a couple of bucks, but sometimes you have to look around for it. It basically splits one of the connectors into two. As long as you have a decent sixe power supply, you should be fine.
If you were a parsley farmer, could they garnish your wages? -
The "Y" adapter is best but you could disconnect your CD-ROM since you can copy on the fly with your CD writer.
Avidemux edit leads to out of sync audio..
By Jmart285 in forum Newbie / General discussionsReplies: 18Last Post: 18th May 2011, 15:35 -
What if the Matrix ran on Windows
By freebird73717 in forum Off topicReplies: 3Last Post: 12th Nov 2008, 20:29 -
dvd editing leads to unacceptable results
By jamesgig in forum DVD RippingReplies: 7Last Post: 18th Sep 2008, 21:42 -
By jamesgig in forum DVD RippingReplies: 2Last Post: 7th Sep 2008, 01:49 -
Weird frame rate issue. Anybody ran into this before?
By dimtim in forum Video ConversionReplies: 4Last Post: 19th May 2008, 08:21
