Can someone tell me if there's a solution for the problem
that I can't find a way to make a slideshow(15 images) in DVD Pro
with just one audiotrack playing in the background.
In iDVD it's a nobrainer, but in DVD Pro you can only make
a slideshow with a audiotrack for every image, as far as I can see.
Thanks in advance
a good solution would be to put together your images in Quicktime and and export to MPEG2. This would give you a video file instead of seperate images, and I dont know if that is what yo uare looking for, but that would work out.
hope this helps. -
yea I am putting a slide show togther and came across the same probelm in DVDSP so I just switched to iDVD, faster and easier but has its draw backs too. the quicktime thing might work but then again the images may not look as still.
EarlyGrace -
if you use Qucktime for the images, you will have no problems i promise.
One "quick" way of doing this is to put together a slideshow in iPhoto and then export it to Quicktime. You can set the duration between images and everyting. the images will remain perfectly still.
Then you can open the resulting .mov file in QT Pro and export to MPEG2.
Enjoy. -
Sorry I dont have an encouraging answerOriginally Posted by kakel
I have the DVD studio Pro Bible sitting in front of me and I looked in it and I dont think that there is a a way to do this.
But how do you allow one soundtrack to play in th background of a slideshow on iDVD I only have iDVD 1.0.
Do I need iDVD 3.0
Thanks in advance -
you can do it with iDVD 2, and 3But how do you allow one soundtrack to play in th background of a slideshow on iDVD I only have iDVD 1.0.
Do I need iDVD 3.0
EarlyGrace
Replacing DVD Audio track (how does this sound?)
By ArtOfLosingMFZB in forum Newbie / General discussionsReplies: 2Last Post: 21st Apr 2012, 16:00 -
What is the easiest way to add or replace existing audio DVD sound track
By pwangdel in forum Authoring (DVD)Replies: 18Last Post: 2nd May 2011, 02:10 -
Get audio track from DVD Extra instead of film sound track in VIDEO TS
By Josephine in forum Newbie / General discussionsReplies: 4Last Post: 2nd Aug 2010, 13:25 -
DVD Lab Pro - no audio track on dvd
By KlintIstwood in forum Authoring (DVD)Replies: 4Last Post: 17th Jul 2010, 06:47 -
DVD-Lab Pro Slideshow
By Electric Blue in forum Authoring (DVD)Replies: 10Last Post: 10th Apr 2009, 08:43
