Every time i load a DVD compliant mpg file the projected file size is very incorrect,if i then remove the asterisk from "Do Not Convert Compliant MPEG files" the projected file size is shown correctly. Why is this? I canīt seem to get 2 NTSC DVD compliant MPEG on 1 DVD-R,the program wants to convert the files,even though they are dvd compliant,if i then choose the option " Do not convert compliant mpeg files" the project goes up from 4.3GB to 8.7GB why is this??
It is beginning to irritate me very much, that i canīt seem to find a decent program which let me put 2 movies on 1 DVD-R.
My mpeg files are NTSC 720x480 with a variable bitrate of min. 2500 avg. 3000 max. 4000 with 48khz audio,the low bitrate is on purpose so i can fit 2 movies on 1 DVD-R. But as you can see MF 2.0 keeps telling me the project will be around 8.7GB,which is incorrect..
If it aint broke, donīt fix it.
HAPPY 100th HARLEY-DAVIDSON
Keep up the assembly line Willie G. -
What is the MPEG filesize of each file?
3.141592653589793238462643383279502884197169399375 105820974944 -
I had a similar problem for PAL, are your file audios MPEG 2 and 48000?
help with Ulead videoStudio?
By wamit in forum Capturing and VCRReplies: 4Last Post: 24th Apr 2009, 09:27 -
GOP length and filesizes (HCenc)
By Movie-Maker in forum Newbie / General discussionsReplies: 4Last Post: 19th Nov 2008, 11:41 -
Sony Vegas Rendering large filesizes!
By HelponvidVeg in forum Newbie / General discussionsReplies: 1Last Post: 3rd Jul 2008, 16:58 -
How does it work from .avi to DVD with filesizes
By herbster in forum Authoring (DVD)Replies: 6Last Post: 10th Dec 2007, 20:17 -
Ulead crashing
By chewie8008 in forum Authoring (DVD)Replies: 5Last Post: 12th May 2007, 09:57
