Is there a porgram out there so I can tweak framrates on MPEG and on an MPEG is there a program that'd let me mess wiht framrates??
MPEG framerates are not specified by an actual exact number that can be changed willy-nilly to any value you desire. They are specified by a coded number that represents the framerate and there's only a few defined framerates that have code values which are available to choose from.
23.97 24 25 29.97 30 59.97 60 are most (if not all) of the values available.
There are a set of programs out there designed specifically to change the coded number back and forth between 29.97 and 23.97 for NTSC/FILM (also 25 and 23.97 for PAL/FILM), but they are probably not what you were looking for.
Few questions regarding LCD tv... that will lead to more questions :)
By ohlookyhere in forum DVB / IPTVReplies: 16Last Post: 15th Aug 2010, 16:50 -
Powersupply questions and fan questions
By yoda313 in forum ComputerReplies: 39Last Post: 8th Sep 2008, 19:08 -
New to DV, I have several questions.....
By Jensen in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 20Last Post: 4th Dec 2007, 00:10 -
SD to HD Questions
By The Sumerian in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 21st Nov 2007, 12:08 -
Got a new 16:9 TV, have some questions...
By sdsumike619 in forum Video ConversionReplies: 6Last Post: 28th Jul 2007, 15:00
