  1. I'm trying to encode a DVD Rip with a VBR to XVCD. I've tryed saving the audio stream as a 44,100khz wav via vitrualdub but it was still out of sync after the encoding. The scary part is: It get's more and more out of sync as the video goes on!!! Why the **** is this happening? Can it be fixed? :'(
    Bravoxena
    Aug 2001
    Finland
    VirtualDub can't handle VBR mp3 audio properly, use Nandub or other modifield Vdub versiions instead for saving your audio as uncopressed wav.
  3. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Or, to use any VDub version:
    Set direct stream copy under audio, then Save wav.
    As you know it's MP3 audio, just rename this newly created wav to ???.mp3
    Now convert this MP3 to wav wit a dedicated mp3 to wav converter, like CDEX.
    Also, be sure to use the same frame rate for your XVCD as your AVI!
    /Mats
  4. When I converted through virtual dub last time, I noticed that the wav's length and the video's length were a few seconds off. I now tried following mats.hogberg's advice and I noticed that when I played the wav file thru media player, it said the length of it was 20-30 shorter than the movie, although when I tried playing it (the wav) to the end, it actually went a few seconds longer than the movie. VERY CONFUSING EH? I'm trying to encode this movie (for the 5th time) and I'll see what happens.
    Bravoxena
  5. I was also confused with DVDx, I want to rip StartWars Episode 2,
    and there is a strange thing:
    simply playing the DVD with DVDx, not encoding, I see the
    movie, all seems to be OK. But suddenly, The movie restart !
    No Error Message, simply restarting !
    If I encode this movie, the same thing appears.
    very strange.
    Is there any pb with multiangle movies ?
  6. UGH! NOTHING WORKED! Just to recap:
    I am trying to encode an Xvid file to SVCD but I get audio sync problems. I also notice that it gets more out of sync as it gets closer to the end of the movie. PLEASE HELP ME! PLEASE!
    Bravoxena
    Dec 2002
    Download a better quality movie? You do realise 'those' movies are encoded VBR for a reason? The guides are pretty much how you fix VBR/AC3 audio for AVI2-whatever conversions.
    To Be, Or, Not To Be, That, Is The Gazorgan Plan
  8. I guess you're you're right. I just feel that the f***in video file has defeated me in the battle. :'( Thanks!
    Bravoxena
