Im trying to framserve with virtualdub to cce and when i try to encode it gives me this error. It says "CCE Encoding failed: Avistreamread() failed
(0x8004406d): A disk error occured while reading the file". Plss someone help!
Try AviSynth instead to frameserve to cce
Its very good and there are quite a few guides here and on doom9.org
if you are re encoding Avi files then you can use FitCD to make the script for you
Can you use frame serving for video conversions?
By johnharlin in forum Video ConversionReplies: 2Last Post: 2nd Mar 2011, 23:39 -
Play an MTS file frame by frame, displaying timecode or frame number
By SeánB in forum Software PlayingReplies: 5Last Post: 5th Oct 2010, 17:26 -
Frame serving
By carlmart in forum Video ConversionReplies: 2Last Post: 2nd Jul 2009, 09:39 -
Vdub frame serving to CCE ?, UPDATE ..Fixed the Error
By theewizard in forum Video ConversionReplies: 15Last Post: 1st Feb 2008, 00:24 -
CCE keeps on trying to change my frame rate?
By friedtofublocks in forum Video ConversionReplies: 17Last Post: 14th Dec 2007, 06:21
