I have a question that I am not too sure about.
I like to convert to CVD and burn to CD
My player only handles up to 2500bit rate.
If I burn to DVD-R instead of CDcan I raise the bit rate over 2500 or does is still see it as a cvd which can only have 2500
Probably a dumb question but was not sure.
i think (!) the 2500kbps limit comes from the drive which is able to read CDs at 2x speed (but no faster).
if this is true you should be able to go beyond 2500 without problems, since the DVD player is able to read DVDs way faster (in terms of bitrate)...
however i don't know for sure, so don't blame if it doesn't work... 8)
bye,
--hustbaer -
i really see no reason to increase the bitrate, you said its a scvd so it thats the case it should like a 2500 bitrate to begin with and you won't be able to improve the video anyways if you increase the bitrate. the video can never be better than the source. so i would just convert it to cvd and put it onto a cd...
well, of course it only makes sense if you do new encodes directly from DVD.
if you re-encode you will always lose quality.
bye,
--hustbaer -
Answer to the original question: Yes, if you burn onto DVD-R you're not bitrate limited. My Philips DVD is also limited to 2500 kbps or so bitrate with SVCD, CVD. However, i recently backd up an old 8mm tape (352x576, avg ~4000, max 9000 kbps) and it plays perfectly (as it should, it's a standard DVD with 1/2 D resolution)
At first I thought the highest possible bitrate that a CVD could play at was 2520kbps. I was wrong, I'm going to encode my CVD's at much higher bitrates such as 3000kbps and such. Thanks RoopeT.Originally Posted by RoopeT
you are just wasting you time it win't help the video since the orginal is at 2500 bitrate
Help with svcd 2 dvd
By tastybaker in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 11th Aug 2010, 09:30 -
Svcd 2 dvd
By GeordieDave in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 8th Feb 2010, 10:05 -
VCD to DVD (not SVCD)
By noyou in forum SVCD2DVD & VOB2MPGReplies: 20Last Post: 19th May 2009, 16:56 -
Can a SVCD video file be burned on to a DVD and played in a DVD player?
By dvdnewbie64 in forum Newbie / General discussionsReplies: 9Last Post: 17th Apr 2008, 20:44 -
How to burn a SVCD onto a DVD?
By php111 in forum Authoring (VCD/SVCD)Replies: 9Last Post: 16th Oct 2007, 02:32
