  1. HI i am a newbie at this and would appreciate any help.
    I am trying to convert a DIVX movie into a vcd so i am using VirtualDub to extract the audio so i am following the instructions on the site and when i go to the Save Wav part it tells me "No audio decompressor could be found to decompress the source audio file". I cannot get round this.
    Thank You in advance for any help
  2. You are missing a codec. Download and install g-spot (tools section). OPen you video in this and it will tell you what codec you need. Find this codec (google?), install it and all should be fine.
